to perform maintenance on your xbox 360 just go to the system blade then select memory, then highlight the hard drive and press on your controller Y,X,X,LB,RB,X,X and a window on the right should come up saying do you want to perform maintenance, you need to press YES
And why would you want to do that?
It sounds as if you are saying what to do to with regards to
Clearing your update cache: This clears out the cache of dashboard, system, and other updates in case something gets glitched and you can't update. Go to the System blade, then select "Memory." From that screen, select your hard drive, then hit "Y" to get to "Device Options." From there, use the controller to enter: X, X, LB, RB, X, X. You'll get a message asking if you want to perform maintenance on the device - select Yes
I would think most do not need to do this.
Capturing XBox 360 in HD
By Hyde! in forum Capturing and VCRReplies: 6Last Post: 3rd Jun 2011, 22:28 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Xbox 360
By roddersuk in forum Newbie / General discussionsReplies: 3Last Post: 15th May 2008, 01:28 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 09:06
