Results 1 to 9 of 9
  1. Hi,
    I'm looking for a program that can record the sound of a VoIP conversation on my PC into a file (mp3,...).
    The program should monitor the Yahoo Messenger and start recording when a call is made through its respective port, without the user of my computer knowing that the recording is going on.
    (the audio version of a keylogger)
    Please let me know if you know such a program.
    Thanks.
    Apr 2004
    Miskatonic U
    So basically an illegal wiretap ?
    There is this : http://www.topofbestsoft.com/index_srp.htm - may or may not be use
    Read my blog here.
  3. Member olyteddy's Avatar
    Dec 2005
    Total Recorder might work too. It has a 'Silent' mode that can monitor a particular program.
    Sep 2007
    Philippines
    Originally Posted by windranger
    Hi,
    Thanks.
    just do a google search my friend...there's plenty of them out there...hope this helps!
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Actually, there is mostly crap out there, and 95% of it only records chat text, not VOIP.
    Read my blog here.
    Apr 2004
    What you need is wireshark to capture VoIP (most likely SIP protocol) decode the RTP and play it back.
    http://www.wireshark.org/
    while decoding and playing it you would then use Goldwave to capture the playback and save to wav or mp3.
    Lawrence S.
    "If it ain't broke, don't fix it" Why is this hard to remember ?
  7. Thanks for all the suggestions.
    I came across this product:
    www.voiceemotion.com/editioncompare.htm
    what do you guys think about the Advanced version of the program..?
    Sep 2007
    Philippines
    good day my friend...... MX Skype Recorder v3.4 ..been using it for almost a year now....just look for it!
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Wow ! One whole program out of hundreds.
    I stand by my 95% crap statement.
    Read my blog here.
