Results 1 to 14 of 14
    Apr 2007
    Canada
    Everything has been working fine until 2 days ago. My system just stopped recognizing my HP DVD Writer and I've tried all possible solutions to re-configure it.
    I'm running Vista Ultimate Sp1 x64
    Tried updating BIOS, updating firmware, looking online for drivers, nothing works. The device is listed as operational as Other Devices in device manager.
  2. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    It would be helpful if you listed the model number of the HP dvd burner.
  3. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Obsolete, buy a new burner.
    Apr 2007
    Canada
    dvd writer 300i
    3.20 (firmware) is all the information I have.
    Originally Posted by [_chef_
    ]Obsolete, buy a new burner.
    I would..but it worked perfectly before.
  5. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Try physically unpluging and repluging the ide cable.
    Donadagohvi (Cherokee for "Until we meet again")
    Apr 2007
    Canada
    I did that (while the computer wasn't running, of course :P). Same results.
    I read somewhere that apparently I don't even have to install a driver. Something must have misconfigured...
    Oct 2005
    666th portal
    they do die..... 3 or 4 years is about the most you should expect from an optical drive. some more, but a lot last even less than that.
    windows has built in driver support so about all you can do is delete the device from the device manager and let windows "find" it as new hardware on the next reboot. it will install by itself.
    Apr 2007
    Canada
    aedipuss, I actually remember this happening in Windows XP a few years ago also.
    I did delete the driver from device manager, went through the process but it says 'Cannot find suitable driver'.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    sounds like the drive controller board has died. is it listed in your motherboard bios properly?
    Apr 2007
    Canada
    The Motherboard (at BIOS bootup) sees the drive properly listed as IDE.
  11. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    I it's time to buy a new dvd burner. They're cheap now at under $30.00 for some brands/models even free shipping going on over at Newegg with some brands. :wink:
    Apr 2007
    Canada
    Yeah, I was thinking about it. I saw a nice Sony DRU190A 20x DVD+R,-R,+DL around $25.
  13. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if you go with ide/ata again make sure to get an 80 wire ide cable to replace the old 40 wire the other one most likely uses.
    Apr 2007
    Canada
    Alright, thanks a lot guys. I'm going to buy a new drive today.
