I have a Canon HV20. Can anyone recommend a good HDV capture software and minimum h/w reqmts to capture and burn DVDs at home. I am using a Dell Dimension 8200 with 2.2 GHz CPU (533 MHz bus), 40 GB HDD, 512 MB RAM, IEEE 1394 card, 8X DVD writer and Windows XP Home. In addition to more RAM what else might I need?
I can help with the first two bits.
Hardware requirements for capturing are the same as for DV so you are OK there.
You can capture HDV using VLC. I created and submitted a How-To guide (which for some odd reason hasn't appeared in the list...). You can read it here:
http://www.enosoft.net/VLCHDVCap/How-To.htmJohn Miller -
I used Sony Vegas 7 to capture. It's better if you have two HDD's; one to run the software and the other to capture to. Your PC might work better if it was a bit faster, but it will probably do. 40 GB can get filled pretty quickly unless you're deleting the captured files after creating your DVD files.
Cannot capture HDV with Canon HV30
By ChrisU in forum Capturing and VCRReplies: 49Last Post: 4th Mar 2012, 22:56 -
Best DV/HDV capture tool?
By cym in forum Capturing and VCRReplies: 6Last Post: 13th Jul 2010, 16:11 -
Cannot Capture HDV into Avid Liquid
By yukon33 in forum Capturing and VCRReplies: 2Last Post: 28th Apr 2010, 12:38 -
Can't capture from HDV tape!
By frlane in forum MediaReplies: 8Last Post: 2nd Jul 2009, 16:43 -
HDV capture
By yonut in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 25th Oct 2008, 11:33
