I'm using the latest version of ConvertxtoDVD 3.0.0.9, I noticed when I'm playing the converted files on a DVD there are some lag spikes a few minutes in between each other, towards the middle/end of the movie. I'm using memorex 16x speed DVD's and burning the movies at 8x speed. Anyone know how to fix this?
Nothing in your post about the source you're converting from. Nevertheless, my assumption is that your problem might begin with the Memorex media. Try doing the burn with Verbatim or Taiyo Yuden discs, and see if this remedies the problem.
I took the 30 pack of memorex dvds back to get my money back and bought maxell dvd's because there were no verbatim or the other kind you recommended. I burned a movie and it played fine without skipping. Thanks!Originally Posted by filmboss80
Software and data files vs. playing movies - special dvd player?
By Haopengyou in forum Media Center PC / MediaCentersReplies: 3Last Post: 18th Mar 2012, 07:55 -
audio lag in .mov to .flv converted files
By french-petzouille in forum ffmpegX general discussionReplies: 5Last Post: 3rd Mar 2012, 13:05 -
medial player stopped playing my movies
By CheekyKid in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2010, 01:26 -
Lag when playing a xvid straight on my LCD TV
By Burner72 in forum Newbie / General discussionsReplies: 12Last Post: 19th Aug 2009, 11:47 -
DVD to H264 with Triple Audio (Vorbis) - results only in lag when playing
By Dannyramsnes in forum DVD RippingReplies: 9Last Post: 8th Sep 2008, 11:31
