Hello,
I'm trying to convert an .mov file to .flv and the conversion is failing due to the codec used to encode the source (I believe).
Here's the source code:
Uncompressed 10-bit 4:2:2
Unsupported codec (id=0) for input stream #0.0
... is there a way to achieve this or will I need to convert the source material first?
thanks!
-dan
Can you play the source in VLC? If so, what does VLC say about it (check info)?
In stubborn cases, you may wish to use VLC's transcode engine to convert the source into something else. If that "something else" isn't what you ultimately want, use high bitrates on the intermediate file to minimize quality loss suffered in the final transcode.
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
quicktime plug in for 10 bit (4:2:2) Uncompressed
By privor in forum MacReplies: 1Last Post: 24th Nov 2008, 12:29 -
Error on Uncompressed 10-bit 4:2:2 1920x1080 QUICKTIME to -> MPG
By peejeedee in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 20:04
