dear all:
this could be simple and you may find it lame but i m facing problems.
i have taken a dvd (video) backup to my laptop, now i want it to burn it on the dvd and watch it on the dvd player with family. but now the problem i am facing is i have burn the dvd and when i play tht dvd to the player the player is not getting its response and says no disc found. and same dvd is running perfect in the desktop dvd and windows media player is able to play it fully.
now what should i do and what software or what extra files should i copy to play this on the dvd player.
please do reply to the topic, thanks in advance.
Note: please move this topic to proper corner if i have posted it in wrong section.
First you need to provide more information
1. is this a commercial disc, or a private, unprotected disc ?
2. How did you copy it to your HDD ? (Software, process etc)
3. What did you have on your HDD that you burned ? (file list)
4. What software did you use to burn the files to DVD with ?
5. What media did you burn to ? (Media ID would be best)Read my blog here.
Hi, I certainly agree with you. Your advice is really very helpful for us.
Thanks a lot!I'M a SPAMMER
panasonic sa-pm08. DVD player unlock required please!
By amandamcintosh3 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Jan 2012, 18:12 -
help required on making simple but 'deep' dvd menus
By lancealittle in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2010, 06:34 -
Making the Xbox 360 DVD or HD DVD player Region Free....is it possible?
By JGDragov in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd May 2009, 13:56 -
Cambridge Audio DVD53RW DVD Player - Region Hack Code Required
By Teac23 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2008, 10:43 -
Need advice making Episodic DVD with DIVX files - play on compat DVD player
By Firewire60 in forum Authoring (DVD)Replies: 5Last Post: 16th Jun 2007, 21:41
