Results 1 to 9 of 9
    Feb 2007
    I had a port/hub and I had my ports forwarded and everything was fine but I bought a wireless n router and when I forward the ports like I had them with the port utorrent shows up as connectable but it moves slow and the internet doesn't move and if i turn utorrent off everything moves fine on the pc and the ps3.
  2. If your D-Link router supports QOS (my D-Link DIR-655 does), then go to the QOS Engine section and enable it. Also, in the same section, add uTorrent and set it's priority to 255. That gives the uTorrent traffic the lowest priority. QOS doesn't throttle your P2P traffic, it just tells your router to give other traffic, like HTTP/FTP/eMail packets, higher priority.
    Feb 2007
    Where would QOS be I cant seem to find it.
  4. In mine, it is the 3rd or 4th button on the left side of the Advanced Settings section. What model of D-Link router do you have?
    Feb 2007
    dir-615
    Feb 2007
    If it helps any my modem is a westell WireSpeed Dual Connect.
  7. It doesn't look like the DIR-615 offers QOS functionality. The only other thing that I can suggest is, in uTorrent itself, to decrease the "Global Maximum Number of Connections" setting to about 130-150. Higher values seem to degrade performance on non-P2P traffic on some D-Link routers.
  8. Mod Neophyte redwudz's Avatar
    USA
    If you aren't familiar with it, the Port Forward site can help sometimes when setting up a router: http://portforward.com/ Also if you are using uTorrent, check their site for some tips: http://www.utorrent.com/guides.php Check their forums also.
    uTorrent is fairly good about not dragging down other connections compared to some P2P clients, but it will always have some affect on your overall bandwidth. Mostly because of number of connections. One option is to schedule it to run when you aren't using your computer for other things, like overnight. And be aware, some ISPs target P2P services and can reduce your speeds, often without notifying you, if they think you are using too much bandwidth.
    Feb 2007
    I posted on the portforward forum and i wierdly suddenly it works before I could change anything
