As there are all kinds of levels of experience of end users out there, I'm trying to write some instructions for accessing some extra content on a DVD. These instructions will be found inside the case. Anything you would change?:
Instructions For Accessing PDF Booklet & MIDI Files
(Note: You must have the Adobe Reader installed to view/print the
booklet. If you do not have Adobe Reader on your system, please
go to http://www.adobe.com/products/acrobat/readermain.html
to download this software. There is no charge.)
Windows Users:
1) After inserting the DVD into your drive, double click the
My Computer icon on your desktop.
2) With your right mouse button, click on the icon for your
DVD drive and then click Explore
3) A window will open showing the folders on the DVD.
4) Click on the MUSIC folder and inside you will find the MIDI
files and the PDF booklet.
Mac Users:
1) After inserting the DVD into the drive an icon will appear
on your desktop.
2) Double click this icon.
3) A window will open showing the folders on the DVD:
For Windows users, not everyone has the MyComputer icon showing on their desktop. Might want to include instructions to handle that situation...
Regards,
George -
Yeah I thought about that actually. But then I figured My Computer is by default shown on the desktop, so the people that NEED these instructions are most likely going to be the same ones whose my computer icon is still on the desktop from the day they bought their computer from Best Buy =) Anyone that is capable of deleting the icon from their desktop is probably aware of how to find ROM content on a DVD.. Think so?
Originally Posted by sdsumike619
I don't think Vista shows it on the desktop by default. Also, I recently purchased two WinXP computers from Dell, and neither of them had it showing on the desktop (I had to add them manually).
Regards,
George -
Ah heck, Vista, I forgot about that since I still use XP... Is the right click on the start menu still available in Vista? I could tell them to right click on their start button, then click Explore.
Or maybe I should just say "Click Start, click on "my computer"...."
Router with good content filtering?
By ron spencer in forum ComputerReplies: 9Last Post: 14th Oct 2010, 19:39 -
Need good software/instructions to extract pics from .iso
By sousabone3 in forum Authoring (DVD)Replies: 4Last Post: 21st Mar 2010, 15:41 -
Exit to DVD-ROM content from a DVD menu
By SCDVD in forum Authoring (DVD)Replies: 7Last Post: 13th May 2009, 19:59 -
Newbie making good progress with 1080i content needing expert advise
By djdrock in forum Video ConversionReplies: 20Last Post: 27th Jun 2008, 11:01 -
Adding ROM content (after the build) question...
By sdsumike619 in forum Authoring (DVD)Replies: 11Last Post: 8th May 2007, 05:05
