I've been searching the net with no luck so far.
Since I got my computer about a year ago, the front headphone and mic outputs have never worked. I've seen that this is a common problem with this onboard sound card.
I've never needed them up until now.
Anyone fixed this ?
Plese move this for me. I can't see how to delete it.
Results 1 to 9 of 9
Your right about it being a common problem, I had exactly the same problem myself and searched the internet far and wide and never managed find a solution until 3 months after building my pc.
http://technicianspot.blogspot.com/2008/02/one-of-my-post-has-to-be-about-headache.html -
Magic!Originally Posted by naza911
O.K. now my front jacks work.... how do I get it to disable the speakers when I plug my headphones in? -
I don't believe it will. It is simply outputting the audio to all of the outputs simultaneously. The circuit isn't designed to disable other outputs when something is connected.
Google is your Friend -
This is what you should get when you click the little spanner by the 'analog'
cannot try it as I do not have front audio
So whats the point of having a headphone jack?Originally Posted by Krispy Kritter
Some people tend to use headphones more than regular speakers or not use regular speakers at all. Obviously, you are wanting to headphones, and having front panel access is much easier than having to reach around the PC every time. All you simply need to do is shut off your regular speakers or use the software solution provided above.
Also, the jack itself can mechanically redirect the signal- try Radio Shack...
Tv with no headphone jack AND rca audio outputs
By gordes04 in forum DVB / IPTVReplies: 27Last Post: 23rd Jun 2013, 21:39 -
Record audio from PC headphone output
By Galadirith in forum AudioReplies: 0Last Post: 25th Jun 2009, 12:43 -
INTEL 478 socket - 775 socket heatsink/fan
By blinky88 in forum ComputerReplies: 7Last Post: 7th May 2009, 10:38 -
Configuring microphone w/ Realtek HD Audio
By Sean O'Scare in forum AudioReplies: 0Last Post: 24th Feb 2008, 07:05 -
Realtek Audio Problems!
By =CrAzYG33K= in forum AudioReplies: 3Last Post: 8th Jun 2007, 06:56
