I just tried to demux DVD movie using PGCDemux, and that was the result:
here's log:
Code:[General] Total Number of PGCs in Titles=1 Total Number of PGCs in Menus=39 Total Number of VobIDs in Titles=1 Total Number of VobIDs in Menus=1 Total Number of Cells in Titles=14 Total Number of Cells in Menus=1 Demuxing Mode=by PGC Demuxing Domain=Titles Total Number of Frames=141700 Selected PGC=1 Number of Cells in Selected PGC=14 Selected VOBID=None Number of Cells in Selected VOB=None [Demux] Number of Video Packs=2217670 Number of Audio Packs=269904 Number of Subs Packs=22378 Number of Nav Packs=9446 Number of Pad Packs=0 Number of Unkn Packs=0 [Audio Streams] Audio_1=0x80 Audio_2=0x81 Audio_3=0x82 Audio_4=None Audio_5=None Audio_6=None Audio_7=None Audio_8=None [Audio Delays] Audio_1=0 Audio_2=0 Audio_3=0 [Subs Streams] Subs_01=0x20 Subs_02=0x21 Subs_03=0x22 Subs_04=0x23 Subs_05=0x24 Subs_06=0x25 Subs_07=0x26 Subs_08=0x27 Subs_09=0x28 Subs_10=None Subs_11=None Subs_12=None Subs_13=None Subs_14=None Subs_15=None Subs_16=None Subs_17=None Subs_18=None Subs_19=None Subs_20=None Subs_21=None Subs_22=None Subs_23=None Subs_24=None Subs_25=None Subs_26=None Subs_27=None Subs_28=None Subs_29=None Subs_30=None Subs_31=None Subs_32=None
what went wrong?
is there any other way to extract the video and audio?
thanks for helping me man!
when i'm using PowerDVD to watch the movie (in its VOB set form) there's no problem,
only when i'm demuxing it...
thats right.Originally Posted by MOVIEGEEK
i want an elementary MPEG-2 stream (M2V or whatever) and an elementary audio stream (AC3 file).
just tried VOBEdit - got the same bad results...
any other advices i can use?
appreciate.
*edit
VLC played it like WMP did. -
Did you rename the extension to .M2V or .M2P?
Does the picture pixelate through the whole movie or just parts? -
Thanks again.
No i didnt,Originally Posted by MOVIEGEEK
i cant really determine which output i'll get.
i guess PGCDemux and VOBEdit created an M2V file by default...
Just parts of it...Originally Posted by MOVIEGEEK
i might also add that the source is a DVD Movie which i copied to my hard-disk.
I performed the demuxing process over the copied movie...
maybe i should demux it directly from the DVD movie (directly from source).
thanks in advanced! -
Sorry,
my bad...
the source is also corrupted...
when i watched it with PowerDVD i was watching directly from source without noticing... (thought it was playing it from hard-disk...)
i guess thats sort of solving it out...
the disk is scratched a lil bit...
and when i copied it to my hard-disk its damaged it or something.
sorry for the bother and thanks again!
Any s/w to reduce audio dynamic range in DVD files WITHOUT demuxing first?
By EmmB in forum Newbie / General discussionsReplies: 1Last Post: 13th Sep 2011, 16:22 -
frameserving dvd to premiere to avoid demuxing, is it possible?
By codemaster in forum EditingReplies: 3Last Post: 7th Jan 2011, 16:11 -
Demuxing Audio Track from a DVD
By stanfield in forum DVD RippingReplies: 9Last Post: 2nd Dec 2010, 03:55 -
Having trouble demuxing a dvd - seems to erase some of the video?
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2009, 13:36 -
Variable FRAMErate dvd demuxing
By gbi in forum Video ConversionReplies: 8Last Post: 11th May 2009, 08:24
