I rarely burn ISO files, but never had any problems until I tried doing it on a new Vista machine.![]()
The approx 700 Mb iso files downloaded fine, but when I stuck a CD into the Tosh's drive, it was 'prepped' and I couldn't find any selection to burn an ISO, so I just copied it for transfer to my workhorse machine. On ejection, there was another delay, while it was closed 'so it could be used on other computers.'
Not.
I was unpleasantly surprised that while the CD showed as full, no icon or filename could be recovered.
Checked the file itself by copying it to a flash drive, sticking it on the old machine, and burning the iso- everything is fine with the file, it works fine.
So... can anybody recommend a link or whatever that disc cusses Vista and burning image files?![]()
Try disabling the CD autorun feature so that only your third party burning application do the job. Never, Never let Vista burn a CD for you.
Remember, Vista is a piece of crap, because of this, it does crappy burning jobs.No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. ..
store video & also burn chapters according to datestamp (vista & dv
By Nicola-Pickle in forum Newbie / General discussionsReplies: 2Last Post: 4th Apr 2009, 08:08 -
Windows Media Audio 9 & Vista
By jasonphillipstx in forum Software PlayingReplies: 5Last Post: 6th Sep 2008, 22:49 -
Encoding & Authoring On Vista Help
By prcole18 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2008, 12:55 -
vista home & \windows\system32 folder
By rancid in forum ComputerReplies: 4Last Post: 1st Jun 2008, 20:41 -
DVD Fab Platinum 3.08.6 & Vista
By ochsfamily in forum Software PlayingReplies: 1Last Post: 19th Dec 2007, 13:10
