I have about 50 hours of VHS footage that I have captured. I have created a ton of AviSynth scripts to clip each captured "tape" into its individual "clips." For example, Tape 1 may have 4 avs scripts each segmenting the tape into individual clips.
My intention was to then use another AviSynth script to compile those clip scripts in a "DVD" script. For example, "Christmas DVD" script would contain all the Christmas clips.
This apparently causes issues with Cedocida/AviSynth/CCE (all MPEG encoders I have tried crash for some reason on the second pass) so I am resorting to plan 2.
My question however is would there be any quality difference between (2 pass VBR)...
1. encoding each individual "clip" script into its own MPEG2 file and then compiling the DVD from the individual MPEGs in my authoring tool
vs
2. dubbing the "DVD" scripts (collection of clip scripts) in VDub to another AVI file and then encoding that gigantic file to MPEG2.
I would assume the first method would be better because you would avoid interframe "noise" during the clip changes. But I am not familiar enough with the intricacies of MPEG encoders to know if it would really make any difference. Thanks!
Whenever you are working with video, you want to convert as few times as possible. Each covnersion will reduce the quality, and since your source is VHS, it is already quite low.
The only thing to watch is the authoring tool. Many tools by default will try to re-encode all of the input files. If you already have dvd compliant mpeg2 files, then this is unnecessary.Google is your Friend
how can i add multiple video clips to play as one dvd???
By Banleno007 in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2012, 10:53 -
Multiple clips form a single video file
By ripper316 in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2011, 13:52 -
Sony Vegas Pro 8 ... transitions application on multiple video clips ???
By holeepassion in forum Newbie / General discussionsReplies: 3Last Post: 20th Feb 2010, 02:04 -
AVI to iPhone, multiple files after encode, no audio?
By wcpfour in forum ffmpegX general discussionReplies: 2Last Post: 23rd Jul 2009, 17:24 -
Recommendations for database software for my home video clips
By lariol in forum Newbie / General discussionsReplies: 0Last Post: 9th Jun 2008, 14:49
