I downloaded an avi file through kaaza and tried to format it through TMPGEnc to burn it to a VCD, when i tried i recieved the following message: "File "C:\WINDOWS\Desktop\My Music\(smr)lotr-cam(3 of 3).avi" cannot open, or unsupported." that is exactly how the message reads, any help would be greatly appreciated!
you might want to try and pass it through divfix it might tell you if the file is broke or what...
(you can find divxfix in the tools section) -
Some .avi files are not able to be read by Tmpg, but just a little. If its the case, you can format it first using Virtualdub ... have luck !!
The easiest thing to do is read the guides on the left and download the codecs for TMPEnc. THen it will work fine
If TMPG won't open and you HAVE the codecs INSTALLED. You need to up the priority level of your DirectShow filter.
Go to OPTIONS, ENVIRONMENTLA SETTINGS, Vfapi PlugIn tab. Rt click on DirectShow Media Filter, and select INCREASE PRIORITY till it works.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
Handbrake encode won't start - one particular file
By Stuckster in forum Video ConversionReplies: 18Last Post: 23rd May 2013, 05:26 -
no sound with newly downloaded .avi file
By JediPM in forum MacReplies: 7Last Post: 30th Dec 2008, 15:29 -
help with eac3toGUI, won't re-encode file
By runLoganrun in forum Newbie / General discussionsReplies: 0Last Post: 6th Dec 2008, 17:32 -
won't encode full file, and will only do certain file formats
By GregDz in forum ffmpegX general discussionReplies: 0Last Post: 21st Jun 2008, 21:27 -
AVI File Downloaded from torrent
By mps in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 10:54
