    May 2008
    just did this dvd works fine on some of my dvd players (Comp) but stand along unit will not play it? Have aLite-on Stand along DVD Recorder that want play it also. Anyone else seen this?
    THANKS
    AKA Gunslinger
    THANKS
    AKA Gunslinger
    I knew guns1inger and you are no Guns1inger. First guess is that you used sorry-ass media. Use Taiyo Yuden or Verbatim or get used to this problem.
    USA
    When you say it doesn't play, what does it do? Does the player reject it immediately or does it try to play? The majority of times the brand of media is the problem. But also using + or - media with some older players can be a problem if one or the other is not compatible.
    But as recommended, try a quality media first. Verbatim is available in many stores. TY needs to be mail ordered. Some Sony media also seems to work well. What brand DVD media are you using at present?
    And your question is not a User Guide. Moving you to the Newbie/General Forum.
    And welcome to our forums.
