You know I've had more problems with Nero........... GRRRR
I'm running XP Home edition, with a Pioneer DV-RW DVR 104, and Nero 5.5.7.2 and I can't burn anything.............
I get a "Invalid field in parameter" error, then a "can't perform disc at once".
I use to get these same errors on my old machine when using 5.5, but 5.0 would always burn my SVCDs just fine (although I had to reload 5.5 to copy CDs.........big pain).
PLEASE someone help me! And, btw, I already tried 5.0 and it doens't like the DVD-RW. Plus, I paid for it and should beable to use the latest Nero anyway.
Here's my log from Nero:
Windows XP 5.1
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 12:06:00 PM
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.41, size=155715 bytes, created 2/2/2002 9:42:54 AM
Nero Version: 5.5.7.2
Recorder: <PIONEER DVD-RW DVR-104> Version: 1.10 - HA 1 TA 0 - 5.5.7.2
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI
CD-ROM: <ASUS CD-S400/A> Version: 2.1N - HA 1 TA 1 - 5.5.7.2
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 4D080H4 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-104 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : ASUS CD-S400/A atapi Port 1 ID 1 DMA: Off
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 61865984 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523808kB)
Free physical memory: 232MB (237896kB)
Memory in use : 54 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Wizard: Off
CueSheet
7.2.2002
9:23:11 PM #1 Phase 90 File dlgbrnst.cpp, Line 1436
Buffer Underrun Protection activated
9:23:11 PM #2 Text 0 File Reader.cpp, Line 117
Reader running
9:23:11 PM #3 Text 0 File ThreadedTransferInterface.cpp, Line 679
Setup items (original item values)
0: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
2 indices, index0 (150) provided
original CD pos #0 + 300 (300) = #300/0:4.0
relocatable, CD pos for caching/writing not required/not required, no patch infos
1: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
13 indices, index0 (150) provided
original CD pos #0 + 1 + 24564 + 46091 + 50092 + 10285 + 28745 + 66883 + 23223 + 48547 + 21314 + 38789 + 226 (358760) = #358760/79:43.35
9:23:13 PM #4 Text 0 File DlgWaitCD.cpp, Line 194
Last possible write address on media: 359848 (79:59.73)
Last address to be written: 359212 (79:51.37)
9:23:14 PM #5 Text 0 File DlgWaitCD.cpp, Line 1331
Recorder: PIONEER DVD-RW DVR-104;
CDR code: 00 97 26 11; OSJ entry from: POSTECH Corporation
ATIP Data:
Special Info [hex] 1: F0 00 B8, 2: 61 1A 0B (LI 97:26.11), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
9:23:16 PM #6 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder PIONEER DVD-RW DVR-104 for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x20 Close CD
Tracks 1 to 2:
TRM_DATA_MODE2_2336, 2336/0x0, ISRC "", FilePos 0 350400 1051200
TRM_DATA_MODE2_2336, 2336/0x0, ISRC "", FilePos 1051200 1401600 839464960
9:23:16 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 679
Setup items (after recorder preparation)
-> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 300 blocks [PIONEER DVD-RW DVR-104 ]
-> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 358760 blocks [PIONEER DVD-RW DVR-104 ]
9:23:16 PM #8 Phase 36 File dlgbrnst.cpp, Line 1436
Burn process started at 8x (1,200 KB/s)
9:23:17 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
9:23:17 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 1950
Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #450
9:23:17 PM #11 Text 0 File Mmc.cpp, Line 15217
Set BUFE: supported -> ON
9:23:17 PM #12 SCSI -1067 File Cdrdrv.cpp, Line 1207
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x01FC45C8
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x00
CDB Data: 0x5D 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x88 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x26 0x00
9:23:17 PM #13 mmc -1067 File ThreadedTransferInterface.cpp, Line 1394
9:23:17 PM #14 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1394
Could not perform start of Disc At Once
9:23:17 PM #15 Phase 38 File dlgbrnst.cpp, Line 1436
Burn process failed at 8x (1,200 KB/s)
9:23:17 PM #16 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\NeroCD2k.sys': Ver=1.0.0.9, size=44227 bytes, created 2/2/2002 9:36:44 AM
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 12:06:00 PM
Here's a little more info..........
I was able to burn a small SVCD mpeg to a disk by using nero's SVCD setting (instead of the "burn image" bin/cue that I usually do), BUT when I tried a Full Mpeg (one that would fill the entire CD) then I get the error again.
Please help.............. Nero's tech is NO help at all. Btw, I tried fireburner last night and I'm getting the same "Invalid field in parameter" error. UGH!
Anyone?
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 03:12 -
Parameter Incorrect?
By The Monkees in forum ComputerReplies: 3Last Post: 18th Mar 2010, 17:41 -
Nero Vision 5 with ADVC-100 - wrong field order in NV5
By vcddude in forum Capturing and VCRReplies: 10Last Post: 28th Nov 2008, 17:22 -
upper field or lower field first? how should I export from premiere
By phpmysql348 in forum EditingReplies: 2Last Post: 6th Sep 2008, 22:54 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 5th Dec 2007, 23:19
