Dose any one know the hack for Magnavox DV200MWS In order to watch my DVD I need to get the code for it thanks![]()
Assuming you actually tried to find a hack and failed (many people don't even bother before posting, so it's a big assumption on my part), you should be aware that all DVD players do NOT have hacks. Some simply cannot be made region free. Others may have hacks that worked at one time but the hacks no longer work because of hardware changes by the manufacturer during the production run.
If there really is no hack for your player, it is possible to rip the DVD on a PC and re-burn it. Without region coding, your player may play it, but if it's a PAL DVD, you could have issues if your player can't convert PAL DVDs to NTSC output.
Which is better, Phillips or Magnavox BD-R?
By jbitakis in forum Blu-ray RippingReplies: 2Last Post: 18th Nov 2011, 14:35 -
My Magnavox problem
By LadyLiete in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Jun 2010, 06:03 -
Magnavox ZV420MW8
By Alon_O in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th May 2010, 09:33 -
Magnavox BDP170MW8
By donk in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th Feb 2010, 13:39 -
magnavox nb500mg1f
By jswatkins in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Dec 2009, 00:20
