  1. I extracted the VOB files from my home video DVD. Then I extracted to mpeg2 using VOB2MPG v2.5. The resulting MPG file plays fine (video and audio) UNLESS I move the slider to another part of the video in which case I hear a loud static sound (similar to sound you hear on old televisions).
    ALSO...
    * I extracted the middle part of the MPG file and saved as a new MPG file. The entire clip has the static sound.
    * I played the VOB files in Media Player Classic and they sound fine.
    Here are my installed audio codecs:
    CODEC Manufacturer Description Status File Version Size Creation Date
    c:\windows\system32\sl_anet.acm Sipro Lab Telecom Inc. Sipro Lab Telecom Audio Codec OK C:\WINDOWS\system32\SL_ANET.ACM 3.02 84.00 KB (86,016 bytes) 8/3/2004 8:56 PM
    c:\windows\system32\msadp32.acm Microsoft Corporation msadp32.acm OK C:\WINDOWS\system32\MSADP32.ACM 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 14.50 KB (14,848 bytes) 8/3/2004 8:56 PM
    c:\windows\system32\msgsm32.acm Microsoft Corporation msgsm32.acm OK C:\WINDOWS\system32\MSGSM32.ACM 5.1.2600.0 (xpclient.010817-1148) 19.50 KB (19,968 bytes) 8/23/2001 10:00 AM
    c:\windows\system32\imaadp32.acm Microsoft Corporation imaadp32.acm OK C:\WINDOWS\system32\IMAADP32.ACM 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158) 16.00 KB (16,384 bytes) 8/3/2004 8:56 PM
    c:\windows\system32\msaud32.acm Microsoft Corporation Windows Media Audio OK C:\WINDOWS\system32\MSAUD32.ACM 8.00.00.4487 288.00 KB (294,912 bytes) 8/3/2004 8:56 PM
    c:\windows\system32\tssoft32.acm DSP GROUP, INC. tssoft32.acm OK C:\WINDOWS\system32\TSSOFT32.ACM 1.01 8.00 KB (8,192 bytes) 8/23/2001 10:00 AM
    c:\windows\system32\msg723.acm Microsoft Corporation msg723.acm OK C:\WINDOWS\system32\MSG723.ACM 4.4.3400 116.00 KB (118,784 bytes) 3/30/2008 9:56 PM
    c:\windows\system32\msg711.acm Microsoft Corporation msg711.acm OK C:\WINDOWS\system32\MSG711.ACM 5.1.2600.0 (xpclient.010817-1148) 9.00 KB (9,216 bytes) 8/23/2001 10:00 AM
    c:\windows\system32\iac25_32.ax Intel Corporation Indeo® audio software OK C:\WINDOWS\system32\IAC25_32.AX 2.05.53 195.00 KB (199,680 bytes) 8/3/2004 8:56 PM
    c:\windows\system32\l3codeca.acm Fraunhofer Institut Integrierte Schaltungen IIS Fraunhofer IIS MPEG Layer-3 Codec OK C:\WINDOWS\system32\L3CODECA.ACM 1, 9, 0, 0305 284.00 KB (290,816 bytes) 8/3/2004 8:56 PM
    c:\windows\system32\ac3fil~1.acm Not Available AC3Filter ACM codec OK C:\WINDOWS\system32\AC3FILTER.ACM Not Available 372.00 KB (380,928 bytes) 5/10/2008 11:53 AM
    Try play with VLC(it has built in audio codecs), does it sound the same?
