I'm starting from a fresh install of XP Home Ed. with SP2, and no other on-line updates. I downloaded (but haven't installed) MS's stand-alone update file that is 316MB in size. The overview text says I, as System Admin., besides all the "regular" updates, can choose to install each of these updates: MMC 3.0; MSXML6; Microsoft Windows Installer 3.1 v2; Background Intelligent Transfer Service (BITS) 2.5; IPsec Simple Policy Update for Windows Server 2003 and Windows XP; Digital Identity, Management Service (DIMS); Peer Name Resolution Protocol (PNRP) 2.1; and Wi-Fi Protected Access 2 (WPA2).
Q 1: How do I know which of these optional updates I need or don't need? I read the descriptions of each, but other than the Wi-Fi one (I don't use Wi-Fi), it's not very clear. Or should I just install them all?
I had MS "Windows Updates" check my computer for necessary updates, and it listed SP3, but the file size to download was only 70 MB.
Q2: What is the difference between the two "SP3" update files, besides 246MB?
There is an ISO version that is designed to burn to CD that is larger than the regular Redistributable version. I've installed both version now with no noticeable differences. Never once did either of them offer me the option to choose any optional components to install.
Install SP3 at your own risk and with the willingness to completely reinstall everything should you have problems. Early reports on SP3 are just awful with quite a few people reporting random reboots and others saying that their PCs will no longer boot at all and they had to reinstall everything. Some people do have no problems. Do you feel lucky? When it comes to Microsoft, I don't install Service Packs for quite a while until I am reasonably sure it won't destroy my system. I didn't install SP2 until many months after it came out.
does SP3 FORCE WGA on the enduser?
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
I just found this link that helps explain the optional updates in more "layman's" terms (compared to MS's descriptions):
http://blogs.technet.com/askperf/archive/2008/04/29/windows-xp-service-pack-3-rtm-rtw.aspx
Still not completely sure of which ones I need to install, but this may help others with the same question. I, too, am holding off on the install for awhile because of some of the problems I've read about with this update. Since I haven't done any of the usual incremental updates that have come out since SP2, it would be more difficult to find and resolve a problem if something goes wrong after the "mass" update.
ron spencer: What is WGA? -
Windows Genuine Advantage - It was an initiative started by Microsoft to identify versions of Windows using non-licensed keys. If you were deemed to be illegitimate, you would get nagging popups that would prod you to buy a licensed version of windows.Originally Posted by CSULB71Believing yourself to be secure only takes one cracker to dispel your belief.
WinXP SP3 Problems
By bevills1 in forum ComputerReplies: 5Last Post: 1st Aug 2010, 22:48 -
Can't install XP SP3
By JudgeGarth in forum ComputerReplies: 9Last Post: 5th Dec 2008, 00:07 -
EVR on XP SP3 with MPC-HC
By THX-UltraII in forum Newbie / General discussionsReplies: 0Last Post: 10th Sep 2008, 06:30 -
XP SP3 Problems
By alegator in forum ComputerReplies: 15Last Post: 21st Jun 2008, 11:16 -
Reminder About XP and SP3
By MOVIEGEEK in forum ComputerReplies: 17Last Post: 6th Mar 2008, 11:45
