I have a notebook computer that had a hard drive failure. I am replacing the hard disc. The system restore disc is XP Home SP2. Would it be better to download the SP3 update and load it before I do any online updates? I understand SP3 has all of the prior updates in it. If this is the case, I assume there is no need to do online updates before I do the SP3 update. Am I missing something?
You are probably placing too much faith in MS to 'Get it right'.
I think I would install SP2 first, then SP3 as that's apparently what they intended. Then SP3 should 'only' add the newer updates. Even with all that, I suspect you will still have to be adding more regular updates for a few days more from off the net.
I passed on SP3 as, just by itself, it's doesn't seem to add anything that I didn't already have or need from regular updating. -
There is some question about SP3 being ready for prime time. Last I heard, it was not officially the final version.
Here's some recent discussion ...
https://forum.videohelp.com/topic350239.html?highlight=winxp%20sp3 -
I'm sorry, I didn't make myself clear. My system restore disc which I will be loading onto a new drive is at SP2 level. My question is should I load a downloaded SP3 install file after I reinstall Windows rather than do all of the SP2 updates via Windows Update first and then do the SP3 update? I don't want to take a lot of time to bring SP2 up to date with Windows Update if SP3 is going to catch me up with those updates.
I would do it that way..
I'd install SP3 before I even connected the PC to the internet -
No, my mistake, I misread your original post.
Installing SP3 would likely be much faster than all the individual downloads.
Well, that was painless. I installed XP SP2 and then installed the full download of SP3 (not via Windows Update). It went smoothly with no surprises.
System Restore
By tcory in forum ComputerReplies: 10Last Post: 21st Dec 2010, 02:13 -
System Restore oddity!
By Soixante in forum ComputerReplies: 2Last Post: 9th Sep 2010, 12:46 -
system restore problem
By Willy5157 in forum ComputerReplies: 2Last Post: 11th Oct 2009, 17:46 -
What does it mean? Create a system restore.
By alintatoc in forum ComputerReplies: 4Last Post: 24th Mar 2009, 04:41 -
System.UnauthorizedAccessException error after WinXP SP3 install
By scoop46 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Oct 2008, 09:03
