I have 2 recorders, a Panasonic ES15 & Lite-On 1107. My +RW discs have become unrecordable on the LiteOn one by one lately. I tried reformatting them in the Panni. Did not help. Is that formatting causing the problem? What is the remedy?
DVD+RW tend to die pretty quickly. Turn the disc over, pull out a magnifying glass. I bet you'll see small pock marks and/or creaters in the phase material. The discs are toast. Trash them.
But these disc still work with the Panny. I was thinking there may be some format difference between the two machines. But on reading the manuals, they are supposed to both record in +VR format on +RW discs. Things just don't add up.
There's no difference other than if the disc was formatted in one particular unit, it should not be formatted by the other.
There's also slight variations between lenses and firmware to contend with.
This is normally why the disc's appear to have a shorter life span... normally just being finicky or picky, but it is recommended that which ever unit first formatted the disc, then it stays with that unit till it quits.
I should add when I mean "normally", this is in reference to swapping the disc between multiple recorders, when considering part 2. -
I second the notion of only formatting or recording a RW disk on one machine (although it plays on any).
I found out how quickly the disks died when mixing them between my PC and my Panasonic recorder.
As a side note, I could recover some of them by doing a 'Full Erase' using IMGBurn; subsequently, I marked the disks so that I wouldn't mix them again.. -
During the weekend I also find a way to revive the +WR disc to record in the LiteOn. I recorded a short title on the Panny. to check if the disc is OK. Then I put the disc in the LiteOn and erase it. After that I was able to record with the Lite. I repeated that with another disc and confirmed it true. Problem seem to be solved, but no logic to it.
LITE-ON iHES 106 BD-ROM + PowerDVD 8 cannot play Blu-ray disc
By eppingwest in forum Software PlayingReplies: 2Last Post: 23rd Apr 2010, 14:51 -
VHS and DVD player. recordable hard disk.
By katiefaery in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Oct 2009, 13:13 -
Is Backing up DATA in Blu Ray Recordable Discs Reliable?
By faramith in forum ComputerReplies: 9Last Post: 8th Oct 2009, 10:46 -
Not Recordable errors just started
By dfm1981 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jul 2009, 13:50 -
signal not recordable: Sony RDR GX 330
By rjl24 in forum Newbie / General discussionsReplies: 3Last Post: 5th Mar 2008, 10:43
