hi, i have 63 short videos, create with VMG menu, and 7 vts, but when i want
to compile , i get message " Out Of Memory " i try to restart pc, free up memory
but it still same, ( dvd lab pro )
need help please
				Results 1 to 20 of 20
	i try this way :
 1. compile each vts with vts menu
 2. then create a VMG menu
 3. attach externall vts
 is it true like this ?
	but the problem is , when i connect from vmg menu to vts 1, i cannot connect to vts 2
	i draw link from VMGmenu->VTS1 , it done
 but i can't draw link from vmgmenu to vts2, vts 3.....
 if i draw link from vmgmenu to vts2, the link from vmgmenu to vts 1 dissapear
	Originally Posted by pcb
 Why have you separated them out to 7 VTS's. Is it possible to cut that down to 5 or 6 VTS's ?
 Using External VTS's will usually require some additional scripting to get the navigation you really want (depends on how complex you want to make the navigation).
 Regards,
 George
	cause each grup that contain 10 videos is different from each other grup.
 each vts that contain 10 videos ( not include vts 7 ) has different purpose
	Can you put 20 into one VTS, and then control playback using Playlists for the different groups?Originally Posted by pcb
	If they all have the same attributes (framerate/resolution/audio format/aspect ratio) then breaking them into different VTS's is arbitrary and not required from an authoring point of view. Indeed, as you have found out, it can complicate the design for no good reason.
 Design your menus properly to keep the user seeing the right groupings, but author more logically in the background.Read my blog here.
	oh , i just realize i wrong all this time between draw link ( end connection links ), and draw button links, this explain why i can't draw connections.
 thank you guns1inger for all your help
 thank you GeorgeW for all your help, maybe i will use Playlists for other cases
	DVD lab has a problem "Out of Memory" when you try to compile more than 6 separate VTS.
 This was discussed a few times on Lab forum.
 The way around is to use External VTS, but that gets more complicated.
 If you are familiar with PgcEdit, I would compile project using DVD Lab with VMG menu and all buttons necessary for navigation. Import it to PgcEdit and assign navigation to each External VTS from VMG there.
	In that case, check this thread in Lab forum, hope it helps.
 http://www.mmbforums.com/ipb/index.php?showtopic=20180
 If you want to do more things like this, look into DVDRemake Pro, it is also DVD navigation command editor, but easier to use than PgcEdit, not free thou.
  Vegas 8 - "System low on memory. You may be able to reduce memory usagBy sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16
  Menus in DLPBy ckurowsk in forum Authoring (DVD)Replies: 1Last Post: 14th Oct 2008, 23:30
  I just adeed another 2GB Memory and Total says 3.25GB MemoryBy videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 07:19
  I'm still trying to determine how much memory is in thus USB memory stick.By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 15:31
  DLP - Video errorsBy flipzoso in forum Authoring (DVD)Replies: 5Last Post: 28th Jun 2007, 09:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
