I want to get this disc build going before I go to sleep since it will take all night. If I want to specify a ROM content folder on the DVD, it seems like I remember some strange issue where I had to create a dummy folder and then put the actual folder with the content in that dummy folder. And then I choose the dummy folder when selecting it in Encore CS3 as the ROM folder.
Is this accurate? Or do I just select the folder with my content in it?
In other words, on the final DVD, I want to have
VIDEO_TS
MUSIC
So would I create a /dummy/music and select the dummy folder?
Thanks!
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
Authoring with Encore CS3, mastering with GPME - when to add ROM?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 13th Sep 2010, 13:04 -
Adobe Encore CS3 - quick way to create 100 menu links?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 4th Apr 2008, 22:17
