Hi, I was wondering does sound preview along with video in AviDemux? I know that my .avi has audio when I load it in, but for the life of me, I cannot get AviDemux to recognize it.
What I am actually to do is find a program that can resize my .avi files with black borders to compensate for my Tvs overscan. Vdubmod will work on some .avi but it doesnt like something about some of these newer ones. AviDemux has the option to add borders which is what I need, but obviously I need sound as well.
Any advice?
Thanks if advance!![]()
What is AVI Demux saying ? Or is it that you simply can't hear anything ?
If it is the latter, Edit->Preferences->Audio Tab : Set Audio Output to Win32
If you are getting an error message then you really need to tell us what it is, or we are just guessing.
You might also use G-Spot or MediaInfo to confirm what sort of audio codec you may be missing.Read my blog here.
Hey, thanks for the reply. That did the trick. I thought I looked at everything. but I obviously missed the preferences tab
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
What tool/s can I use to Mux/Edit H264 in FLV container? Avidemux only does
By tigerb in forum Newbie / General discussionsReplies: 9Last Post: 8th Dec 2011, 22:03 -
Avidemux - audio
By avextraxjp in forum Video ConversionReplies: 4Last Post: 5th Sep 2010, 22:29 -
after using avidemux, audio is out of sync
By michael12happy in forum Video ConversionReplies: 2Last Post: 26th Apr 2009, 09:48 -
Disable audio in Avidemux
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 22nd Sep 2008, 10:15
