Hi , I have some compressed videos that are divx , and I want to be able to mute or edit out audio potions of the video for example coarse language words without cutting out the video, and without having to recode the video again after editing. Can anyone recommend a video editing program for windows xp that will allow me to do this. The editing program can be either freeware or commercial as long as it does what I want fast and easy as I am new to this.
Also I would like to be able to do the same with vob video files as well.
Thanks in advance.
For AVI files with MP3 audio, I would
Demux the audio with Virtuldubmod (Streams -> Stream List)
Mute the sectiosn you want to hide in Audacity
Export as MP3
Remux with with Virtualdubmod
For VOBs/DVD Structures it is a lot harderRead my blog here.
Thanks guns1inger I will give it a try. Will this method avoid having to recode the video? As I want to keep the video quality without recoding.
Also is there any consumer friendly programs that will allow me to see the video while I edit the sound. This will help me to pinpoint the locations better that I want to mute. -
hokkom asked:
But of course.Will this method avoid having to recode the video?
Keep in mind that such applications have been declared illegal in theAlso is there any consumer friendly programs that will allow me
actual democratic countries. You have been warned.
Most of the commercial audio editors will do it - Sound Forge, Audition etc, but then you could also use an editor to do it as well.You can probably do it in Reaper if you import your video onto a track, then cut the audio up when you want to alter the volume, but it can be bit laggy. You will still have to export the audio and mux it into the video afterwards though.Originally Posted by hokkomRead my blog here.
In case of mp3 audio, there are chances to avoid re-encoding audio using mp3DirectCut.
Thanks for the suggestions guns1inger. I have downloaded Virtualdubmod and Audacity and will give it a try. I do own Audition 1.5 and am quite familiar with it.
Also mp3DirectCut is a nice suggestion for audio files Alex_ander.
Muting the VIDEO, how is this done?
By Devilsadvocate in forum EditingReplies: 18Last Post: 25th Mar 2012, 10:27 -
Final Cut Pro, keeps glitching, then muting audio
By Huntr777 in forum MacReplies: 5Last Post: 18th Jul 2010, 03:08 -
Muting certain parts of the audio track.
By silmarallion in forum Newbie / General discussionsReplies: 4Last Post: 3rd Feb 2009, 06:17 -
Blurring/Muting.
By silmarallion in forum EditingReplies: 1Last Post: 24th Nov 2008, 10:31 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23
