Basically i wish to put 2 dvds onto one disc and have chapters for each disc on the menu page. I only have nero 7.
can anyone please show me how I can do this. The nero manuals are not helpful.
thanks
Get yourself a few more tools.
Either way, unless your burning to DL media, the dual title output from nero will look like rubbish considering the bitrate required ... then there's the audio bitrate question.
Pgcdemux = for demuxing titles
Besweet = convert audio to ac3, 96kbit (don't go lower than 64), this will give more space for video
Dvdauthorgui can do all you need in getting both titles together, and basic menu inclusions
Dvdshrink = to make it fit media (4.3max for SL)
Imgburn = + verbatim DL if considering project will require DL media, and correct layer break.
beyond this, there's re-encoding to lower resolutions supported by dvd standards. -
All of the software in Bjs' list is freeware, so you have nothing to lose. As a shorter option (skipping the demuxing and reauthoring steps), you can build two dvds into one by simply using the reauthor function in DVDShrink. Try TitleWriter to make your menu. (I can't vouch for TitleWriter, but I think others have successfully made menus that way.) After DVDShrink builds the new VIDEO_TS folder, you should burn the disc with ImgBurn. Like Bjs said, consider double layer media.
wow!! i didnt think it would be so difficult and so time consuming.
ill give both ago. Thanks for your feedback and help
software alternative to nero to put a dvd on my HW
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2010, 07:36 -
Taking portions of multiple dvds and put them onto another
By ulremember in forum Authoring (DVD)Replies: 10Last Post: 4th Mar 2009, 19:07 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 11:29 -
Home video too big for DVD. How do I put it on 2 DVDs?
By Saaski in forum Newbie / General discussionsReplies: 12Last Post: 14th Jan 2008, 17:00 -
How to put DVDs on Zen Vision: W
By cali_n_alley in forum Portable VideoReplies: 2Last Post: 28th Oct 2007, 20:14
