I have a 60 gig brand new hard drive. I recently partitioned it with fdisk, and put windows on it. It is only recognizing 30 gigs. I just did a primary dos partition and put the os on, and this is what it says. I have been told to re-partition it, but I don't know how to do that. I have already reformatted the drive and I am playing around with fdisk, and I don't know hot to do this??? Anyone ever encountered this problem.
I hate seeing words put together sometimes like , playing with fdisk don't know what I'm doing, these words just bring out the fear. LOL.
is the drive setup properly in the bios? Also what version of windows are you trying to install? You mentioned dos partition, FAT32 or FAT16?
what size does the bios show it as? Before we jump to partitioning out the drive here. How old is the motherboard? Another thing is check to see if you have the latest bios for your motherboard. Very key thing when dealing with new hardware especially larger drives. Also check out:
http://www.storage.ibm.com/hdd/support/bios338gb.htm
If you don't know the maker of your motherboard check here:
http://www.phoenix.com/pcuser/phoenixbios/motherboard.html -
Since you really don't know what your doing I'd suggest downloading the most recent version of MaxBlast (from Maxtor's website), and create a bootable floppy and pur the MaxBlast on it. Then boot from the floppy and use the MaxBlast software to create your partition. You don't have to have a Maxtor drive to use it (I'm reasonably sure of this). My guess is that other HD manufacturers have something similiar also but I've never used their software because Maxtors rule.
Go here to find MaxBlast
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Problems with DVP5990 and External Hard Drive
By maryp1987 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Apr 2009, 19:28 -
Seagate 1.5 gb hard drive problems?
By kenmo in forum ComputerReplies: 2Last Post: 2nd Jan 2009, 20:56 -
Hard drive speed problems
By toby223 in forum Capturing and VCRReplies: 3Last Post: 17th Jul 2008, 05:50
