Results 1 to 10 of 10
    I am not sure this is the right place for my question but here it goes
    I have 2 movie files, one has the correct audio language, but hard coded subtitles.
    The other has no subtitles but the wrong audio language
    How do I remove the audio from the english version and add it to the movie with the wrong language, I may will have to add a delay to match the video and audio
  2. Member daamon's Avatar
    Melbourne, Oz
    What format are the movie files in? MPG? AVI? FLV? Etc. This will determine what the best tool (or tools) is.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    sorry...the movies are AVI
    Apr 2004
    Miskatonic U
    Do they have the same frame rate and running time ?
    Read my blog here.
    Aug 2005
    coocoo
    demux audio avimuxgui or virtualdub
    For the video that has the correct audio
    fps: 25.00
    105301 Frames 1:10:12.04 length
    For the video that has the wrong audio but no subs
    fps: 23.976
    105235 Frames 1:13:09.18 length
    Apr 2004
    Miskatonic U
    You will have to demux the audio you want, load it into audacity and change the tempo to make it fit the length of the video you want to match it to, then you can mux the two together.
    Read my blog here.
    how do I change the tempo?
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Look under the list of Filters and find the one that adjusts the length. I am pretty sure it is called Change Tempo or similar
    Read my blog here.
  10. Mod Neophyte redwudz's Avatar
    USA
    This isn't authoring. Moving you to Newbie / General discussions Forum.
