Hi all!
Currently have an avi file with 560x240 resolution par 1.000 (1:1) that I like to make a dvd from
My TV is 4:3 screen and not changing any time soon.
When I use ConvertXtoDVD, it converts the movie to 16.9 that ends up cropping the movie screen more evedent in the title bleed of the titles beyond the screen
To make matters worse I am lost to find the exact size because my tv PAL and not NTSC as this avi file is.
What can I do to remedy screen resoltion problem in this case?
Thanks a bunch
Check your settings and ensure you have the output set to 4:3. You will end up with black bars on the top and bottom, but it should preserve the aspect ratio.
I typically just burn my avi files to DVD as data and play them back on a Divx supported player. Saves a lot of time, effort, and money converting files.Google is your Friend -
I doubt if the video is being cropped. More likely it's just your TV set's overscan.Originally Posted by drwho
If PAL, it's 720x576, like most PAL DVDs. But if you'd like to make sure, open a VOB in DGIndex, GSpot, Bitrate Viewer, ReStream, or a number of other apps.To make matters worse I am lost to find the exact size because my tv PAL and not NTSC as this avi file is. -
If you are using ConvertXtoDVD 3 you can add overscan borders in the application. If you are using an older version, change to FAVC or DVD Flick instead. Both of these have overscan border functions built-in.
Read my blog here.
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
Screen resolution and video rsolution
By vcd_user in forum Newbie / General discussionsReplies: 5Last Post: 31st Jan 2011, 14:28 -
PC to TV screen resolution question
By majel in forum DVB / IPTVReplies: 15Last Post: 28th Jun 2010, 10:22 -
Youtube Default Screen size / resolution
By Juc1 in forum Video Streaming DownloadingReplies: 4Last Post: 7th Apr 2010, 06:48 -
Screen resolution LCD and PLASMA?
By Rudyard in forum DVB / IPTVReplies: 5Last Post: 26th Jun 2007, 02:25
