I use GFD to author DVDs from my Hauppauge PVR on my laptop. The flow is Hauppauge MPEG2 -> PVA Strumento (to demux) -> GFD to author, using 'Visual Chapter Editor' to add chapter marks at the beginning of each video segment (thus eliminating the commercials). The problem occurs in the last 20 to 120 seconds of each title. The picture will freeze ( the DVDplayer bitrate counter drops to zero) and the sound continues. It's not the media (even happens with Verb) or the amount on the disk (most disks are two titles with 90 minute total run time). Any suggestions at what to look at or try?
1. Try to demux your Hauppauge MPEG2 files with ProjectX (BTW: You can also cut out the commercials with ProjectX!).
2. If the streams are 100% DVD compliant (i.e. 720x480), try to use the muxman engine in GfD (if you haven't tried it yet). See: http://download.videohelp.com/gfd/Help/DefaultPermSettings.htmlGUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanx a Mega Byte! MuxMan worked like a charm. Faster too. Yeah, other folks have suggested actually eding out the commercials, but I record a one hour show (LOST) and a half hour show (Earl) on a disk so I don't need to waste the time to save the space. It also gives me the option to let the commercials run, if I want (popcorn, bathroom break)...
Question about error with Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 27th Nov 2008, 07:38 -
GUI for DVDAuthor File format (.gfd files)
By tacman1123 in forum Authoring (DVD)Replies: 6Last Post: 6th Jun 2008, 17:45 -
DVD SLIDESHOW GUI and GFD
By CM07 in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2007, 08:55 -
DVD Author Gui
By Flying Doctor in forum Authoring (DVD)Replies: 4Last Post: 1st Aug 2007, 09:12 -
GUI For DVDAuthor (GFD) won't let me add audio
By rail in forum Authoring (DVD)Replies: 9Last Post: 14th Jun 2007, 03:53
