    Feb 2008
    I have a large number of ISOs that are split into multiple files (.I00, .I01, .I02, etc.). I'm working on a project to convert all these to mp4 for the content owner. Up to this point I've been using ISObuster on my Windows machine to extract the AUDIO_TS and VIDEO_TS folders, then I encode on my Mac using Handbrake. I'd like to get the ISO extraction process over to my Mac so I can do the whole thing in one place. What do you recommend? I'm not burning these to DVD so I'm not concerned about that functionality.
    Thanks in advance!
  2. You could join your split files to the original ISO with cat from Terminal or one of the GUIs such as Machacha.
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Rename the files with extension i00 to i0x as follows:
    - filename.i00 => filename.iso.001
    - filename.i05 => filename.iso.006
    Then use the program Split & Concat (a GUI for "cat from Terminal") to join the files and make an ISO.
  4. Any ISO I've ever had on my Mac, either on the desktop or on a disc in the drive, simply 'becomes' a virtual DVD (AUDIO_TS and VIDEO_TS files displayed) on my desktop when I double-click on the ISO file. The virtual DVD then works - plays, can be extracted to constituent parts, etc. - just like a real DVD.
    Michael
