Right now I'm playing around with the trial and what I'd like to do is find an easy program that accepts m2ts (this program does) and lets me max out the mpeg2 (vob) video. I believe 9500 is the max for DVD compliance and I can only get the program to encode at about 7800 when I bump the profile to 8400 MB (or something like that).
I attempted to increase the size to 10000 MB thinking I could 'fool it' into encoding at a higher bitrate but 'convert' balked and reset it down to 8400ish - claiming it was too big to fit on a DVD. I don't care about that because I'm not necessarily trying to fit the file onto a DL DVD.
Anyone know where the profiles are stored in this software and how to tweak them in the registry.? It would be much appreciated.
I already understand why it's that way. And that's not what I care about. It accepts .m2ts easily and that's what is most important to me.
If anyone knows if the profile is easily hackable/modable I would appreciate the info. All I really want to do is increase the final size to 10000 MB (Because I assume the conversion would increase the bitrate upwards. I will also try demuxing the source and allowing convertx to use all 8400MB on the video and see what results I get.) -
The bitrate is variable based on the length of your source files. In other words, it only makes the bitrate decision when it's ready to encode. So try it with less .M2TS files. I doubt it'll go above 9500, though.
convertx is not a standard encoder that you can alter all it's settings, and is not meant to be. it is for those that want easy and not a lot of settings to fret over.
if you want a "real" encoder you can set the way you want, you're going to have to look elsewhere.--
RipBot264 Profiles?
By shagratt71 in forum Video ConversionReplies: 2Last Post: 13th Dec 2011, 06:00 -
XMediaRecode... Levels and Profiles?
By smackyourfupa in forum Video ConversionReplies: 3Last Post: 14th May 2011, 14:52 -
libavcodec x264 profiles
By Spearmint in forum ProgrammingReplies: 0Last Post: 2nd May 2011, 20:57 -
Player's color profiles?
By juhah in forum Software PlayingReplies: 13Last Post: 20th Feb 2010, 14:22 -
Different Mpeg Profiles
By AndreL in forum EditingReplies: 2Last Post: 11th Jun 2007, 10:00
