Hi, this is my first post to the forum.
I converted a FLV file to AVI, used CCE SP to convert the AVI to MPEG2 for DVD.
The AVI, MPEG2 and Authored DVD play fine on PC, but when the Authored DVD is inserted to my Standalone DVD player, the bottom half of the screen looks like It's stretched by one pixel. This is displayed throughout the movie.
The best way I can describe it is with a demonstration I will post below. I also posted my CCE SP settings. At first I had encoded the MPEG2 with 'Offset line' set to '1' in the Advanced Settings. I did recode the MPEG2 with a offset of '0' but with the same results. Please if you have experience with this, shed some light.
I figure the more info you have the better:
FLV source resolution: 320x240
FLV source framerate: 25 fps
Converted AVI resolution: 320x240
Converted AVI framerate: 25 fps
Converted MPEG2 resolution: 352 × 288 (To conform to PAL 1/4-D1 DVD Standard)
Converted MPEG2 framerate: 25 fps
Audio was converted from MP3 to AC3 streams.
DVD was authored with DVDMaestro.
Took two screenshots of my TV. I have looked into overscan, but this isn't 3-4% of the screen. It's exactly 50%.
I tested the DVD on a Sony Standalone DVD player, and it worked flawlessly. I then tested the DVD on a LiteON DVD / DVR Recorder and it gave me a Disc Error. The original DVD player is a Thomson DVD Standalone Player.
I now suspect that the MPEG2 stream is not encoded to comply to standards. Can anybody look at my settings? -
Overscan (wikipiedia is a good source of information) results in the edges of the picture being "cropped", it isn't a video distortion. Typically, problems such as these are the result of the conversion tool. It could be because of an issue with the original files, improper codec support, or just a crappy tool. The fact that you are working with flv files isn't helping. They are typically low quality and not many of the decent DVD conversion tools support them.
Your settings look fine, so it is likely one of the issues above. You could try a different tool such as DVD Flick which appears to support flv.Google is your Friend
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 13:39 -
.flv only convert half of movie in iSkysoft...please help!
By evision in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2009, 11:20 -
PAL to NTSC renders OK on top of picture, flickers on bottom half
By Exiled_Brit in forum Video ConversionReplies: 6Last Post: 21st Sep 2008, 15:31 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
Youtube .flv files quickly stop playing but will play past half way point
By video1312 in forum Software PlayingReplies: 1Last Post: 20th Sep 2007, 14:20
