    May 2008
    Hello,
    I don't know anything about video editing and need some help.
    I have a Canon Powershot camera that takes movies which it exports as AVI files. If I right-click on the file and look at the Properties this is what it says:
    640 x 480
    Video: Frame rate: 15 frames/sec
    Data rate: 914 kbps
    Audio: Bit rate: 88 kbps
    Audio sample size: 8 bit
    Audio format: PCM
    What I am trying to do is add subtitles to the movies. I am using Adobe Premiere Elements 3.0.
    All I want to do is add subtitles (text) and maybe crop it a little, then save the file out in the same format and at the same quality.
    I have been unsuccessful as this.
    I realized that the Elements version of Premiere does not allow me to change the settings of how videos are imported into the program, so they always import at the default setting of DV-NTSC which has the following properties:
    Timeline: 29.97 fps
    VIDEO SETTINGS
    Frame size: 720 x 480
    Frame rate: 29.97 fps
    Pixel Aspect Ratio: D1/DV NTSC
    Fields: Lower field first
    AUDIO SETTINGS
    Sample rate: 48000 samples/sec
    CAPTURE FORMAT
    DV Capture
    VIDEO RENDERING
    Maximum bit depth: Off
    Preview File Format: DV NTSC
    Compressor: DV NTSC
    Color depth: Millions of colors
    I have fiddled with exporting my final subtitled movie with various settings for the AVI export but none of them seem to be right. They are all either huge files or the quality is poor. I have tried to copy the settings of the original file into the export settings but the quality was poor and it was clearly not the same as the original file. I don't know anything about codecs, and very little about what the different settings mean.
    The movies (which are just our family home movies) will be kept on the computer but eventually I would like to make them into a DVD to play on the TV.
    As a side note, I tried exporting the movie as a WMV file and for some reason I can get a WMV file which is 600 kb (when the original AVI file is 36 MB) which looks fantastic. This is baffling to me, as clearly there is a large loss of data (36 MB to 600 kb), yet this WMV file seems superior to the 100 MB AVI file it tries to export. Why is that?
    I am not sure I can even accomplish what I would like to accomplish using Premiere Elements. I would appreciate any help.
    Thank you,
    JulieCat
    Jan 2007
    Republic of Texas
    The tiny AVI movies you make with a Canon Powershot run at half the frame rate of the standard video that you see on DVDs, TVs, etc. With a data rate of 914 kbps, the images will always look blocky when expanded to a large screen size. Premiere Elements is designed to make movies that can be seen on TV screens. Powershot AVIs are merely mini-movies to watch on a PC video player, like Windows media player. The bigger you make the image, the better to see the compression flaws of the little movies. These types of AVI files do not edit easily. Perhaps someone in this forum can recommend ways to cut and link your AVIs, but do not expect much in terms of picture quality.
    May 2008
    Thanks for your response. I realize what I'm starting with isn't of super quality anyway, and that's ok, but I thought it would be possible to edit the movies and save them in the same quality that they started in. Hopefully that's possible.
    Jan 2007
    Republic of Texas
    You may just want to use Windows Movie Maker and save as an AVI instead of a WMV. Experiment with that, and see what you can get.
    May 2008
    I tried using that and it didn't work for me. If I recall, it didn't let me put any text on.
