Hi, when I had IE6 the method outlined below worked perfectly to backup the Favorites sort order (to make it clear, I'm not referring to backing up the Favorites which can be done from within IE using File/Import-Export, I'm referring to being able to back them up so I can later restore them in the EXACT same custom sort order as originally, so I don't have to manually drag hundreds of bookmarks to the order in which they were originally).
Sort order is not preserved when you transfer favorites to another PC
If you use the Import/Export Wizard or manually copy the URL favorites to another system, the sort order will not be copied to the target system. This is because Windows stores the sort order in the registry. Neither the Import/Export Wizard or manual copy operation will reference the sort order registry key.
In order to have the sort order applied to the other PC, export the following registry from the source PC:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\MenuOrder\Favorites
Save the above key as a REG file and apply this in the other computer. The sort order is now copied/overwritten.
The issue is that in IE7 I checked that resgistry key but it seems to not have the favorites in the original sort order but ordered alphabetically. So how can I do it in IE7? Thanks
I've never the inport/export (I didn't even know it existed), I've always just copied the Favorites folder or burned the Favorites folder to CD to backup.
Google is your Friend -
FAVORITES MOVE TO NEW COMPUTER AND KEEP ORIGINAL SORT ORDER
on old computer in ie go to file/export and export favs. copy (not import yet) that file to new computer.
on old computer go to regedit
r click favorites and export. copy that file to new computer.
on new computer in explore delete all items in favorites.
right click start /properties/customise remove tick from display favorites.
open ie and import the exported favorites file. close ie.
in regedit got to above and delete the whole favorites key then double click the .reg file you saved from old computer and it will put it in the favorites key but with the order from the old computer.
right click start /properties/customise replace tick in display favorites.
Favorites and Bookmarks
By Jomapil in forum ComputerReplies: 3Last Post: 29th Dec 2011, 17:41 -
Favorites
By Jomapil in forum ComputerReplies: 2Last Post: 5th Nov 2008, 16:39 -
favorites missing....
By ray316 in forum ComputerReplies: 3Last Post: 20th May 2008, 14:19 -
Order in which to process the backing up of a movie
By Hurre in forum Authoring (DVD)Replies: 11Last Post: 7th Apr 2008, 10:09 -
I Cant install IE7!
By GangstaRap in forum ComputerReplies: 2Last Post: 16th Sep 2007, 10:03
