I have a sony mini disc DVD camera and downloaded the movies to my hard drive. I want to make a DVD to send to family but am having issues.
With Roxio when I try to add the movies which are in MPEG-2 format I am getting a error saying movie cannot be edited, movie not added. Also on the movie icon it says no attributes available.
With Windows DVD maker it starts encoding the files but gets to 2.1% and says "An error occured while creating the DVD" but doesn't tell me what to do to fix the problem.
Any suggestions or simple solutions. I don't anything about making these DVD's and have spent the last 3 nights working on it.
I would instead try Tmpgenc dvd author and use it's import dvd function, you can do basic editing and make menus and burn without any reconversion.
Or if you want to use roxio you could try vob2mpg on the dvd and then import in roxio.
putting dvd files (VOB) from dvd and using in windows live movie maker
By emmawharmby in forum DVD RippingReplies: 8Last Post: 20th Feb 2012, 06:58 -
Windows DVD Maker alternatives?
By x2x3x2 in forum Authoring (DVD)Replies: 14Last Post: 25th Dec 2010, 15:19 -
windows dvd maker
By tvlreject in forum Authoring (DVD)Replies: 4Last Post: 18th Mar 2008, 10:32 -
Windows movie maker to dvd
By bilbonvidia in forum Authoring (DVD)Replies: 2Last Post: 31st Jan 2008, 17:41 -
Vista Windows Dvd Maker
By tvlreject in forum Authoring (VCD/SVCD)Replies: 1Last Post: 23rd Jul 2007, 19:48
