Found this G.Skill compatability list for my memory and it lists my board.
http://www.gskill.us/144.pdf
I'll try changing the settings in BIOS and see how it goes.
Results 31 to 39 of 39
When you flashed your mobo bios then rebooted did you set to LOAD TO FAIL SAFE DEFAULT SETTINGS? If it's set that way then the mobo should automatically read your GSKILL ram correctly.
No, the website said to load optimized defaults. I did choose the failsafe setting later but didn't notice any change.
I tried using the Easytune software and set it to Extreme and didn't notice any difference but when I just went in and changed the settings according to G.SKILL's instructions, it was set to extreme @ 9x266. I went ahead and set it up for standard performance @ 8X333.
I just ran a benchmark and here are my results.
Results for x264.exe v0.58.747
encoded 1442 frames, 55.10 fps, 3905.42 kb/s
encoded 1442 frames, 56.27 fps, 3905.42 kb/s
encoded 1442 frames, 56.41 fps, 3905.42 kb/s
encoded 1442 frames, 56.07 fps, 3905.42 kb/s
encoded 1442 frames, 15.13 fps, 3952.85 kb/s
encoded 1442 frames, 15.15 fps, 3952.85 kb/s
encoded 1442 frames, 15.14 fps, 3952.85 kb/s
encoded 1442 frames, 15.12 fps, 3952.85 kb/s
Results for x264.exe v0.59.819M
encoded 1442 frames, 60.40 fps, 3880.47 kb/s
encoded 1442 frames, 60.80 fps, 3884.58 kb/s
encoded 1442 frames, 60.80 fps, 3881.18 kb/s
encoded 1442 frames, 60.52 fps, 3881.65 kb/s
encoded 1442 frames, 16.95 fps, 3963.12 kb/s
encoded 1442 frames, 16.95 fps, 3962.98 kb/s
encoded 1442 frames, 16.95 fps, 3962.95 kb/s
encoded 1442 frames, 16.97 fps, 3963.00 kb/s
System Details
Name Intel Core 2 Quad Q6600
Codename Kentsfield
Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Core Stepping G0
Technology 65 nm
Stock frequency 2400 MHz
Core Speed 2664.1 MHz (8.0 x 333.0 MHz)
FID range 6.0x - 9.0x
Northbridge Intel P35/G33/G31 rev. A2
Southbridge Intel 82801IR (ICH9R) rev. 02
CAS# 5.0
RAS# to CAS# 7
RAS# Precharge 7
Cycle Time (tRAS) 20
Command Rate 2T
Memory Frequency 532.8 MHz (5:8)
Memory Type DDR2
Memory Size 2048 MBytes
Channels Dual (Symmetric)
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
max VID 1.325 V
Voltage sensor 0 1.30 Volts [0x51] (CPU VCORE)
Number of processors 1
Number of threads 4
Number of threads 4 (max 4)
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
Package Socket 775 LGA (platform ID = 4h)
Temperature sensor 0 46°C (114°F) [0x2E] (TMPIN0)
Temperature sensor 1 48°C (118°F) [0x30] (TMPIN1)
Temperature sensor 0 52°C (125°F) [0x30] (core #0)
Temperature sensor 1 55°C (130°F) [0x2D] (core #1)
Temperature sensor 3 57°C (134°F) [0x2B] (core #3)
Temperature sensor 2 52°C (125°F) [0x30] (core #2)
Temperature sensor 0 51°C (123°F) [0x33] (GPU Core) -
you should overclock via the motherboard bios. go into bios then hit ctrl F1 to open up Gigabyte's secret settings, click esc and then click on MITweeky thingy. then you can manually set everything to overclock. do a google search on your mobo and I'm sure you'll find how and what settings to change in the bios to overclock.
Thanks for the info. I'll play around with it some more tomorrow. I'm a lot happier with it now that I got it up to 2.66Ghz. It was pretty disappointing seeing it a 2.1Ghz when the stock speed on the Q6600 is 2.4Ghz..
I'm glad I bought the new board and glad I didn't give up and send it back. -
Good to hear you finally got it up and running. Now the real fun starts when you overclock that q6600 w/the gigabyte mobo using the settings in the bios.
I used the G.SKILL PDF file that I linked to above to get to 2.66Ghz 8X333 in BIOS. To get to 3.2Ghz, do I just change the CPU Host Frequency to 400 and the System Memory Multiplier to 2.00?
The only way you'll know is to try it out. If it doesn't work the pc will not boot to windows. Then you'll have to reboot your pc and it will revert back to stock settings. Try googling your mobo model on overclocking and you'll see what others have their systems set to overclock a q6600. That's how I did it with overclocking my wolfdale e8400 cpu.Originally Posted by DarrellS
you should lock the fsb:dram multiplier to 1, not 2. then the ram will be at 400 and with a multiplier of 8 it will net 8x400 = 3.2GHz.
How do you boot into a Linux Partition from a USB Flash Drive?
By Number Six in forum LinuxReplies: 10Last Post: 16th Feb 2009, 16:20 -
New DVD ROM drive, works but PC warns on boot up
By LWC in forum ComputerReplies: 15Last Post: 24th Dec 2008, 18:19 -
HELP! reactivating SATA drive everytime i boot?
By JayArea408 in forum ComputerReplies: 3Last Post: 2nd Sep 2007, 17:12 -
board not finding ide drive
By 123fish123 in forum ComputerReplies: 7Last Post: 13th Jun 2007, 17:19 -
slave drive seems dead, but cannot boot without it
By ted demen in forum ComputerReplies: 11Last Post: 13th Jun 2007, 08:54
