Help. I have so many of these little wall warts and I don't know which one goes with the WinTV-PVR-USB2 MCE-Kit anymore.
Any help as far as Voltage and amperage would be appreciated
	TBoneit,
 I pulled one out of the package, (never used) and the power supply (if it hasn't changed)
 should be:
 * Black
 * Shaped like a mouse (sort of a rounded contour where you hand fits over like a mouse)
 but without the buttons
 specs, as stamped on the p.supply sticky:
 INPUT: AC 100V ~ 240VAC
 50Hz-60Hz 0.3A
 OUTPUT: DC 6V =-= 1.66A
 MODEL No:EPA-101M-06
 Note, mine is not the MCE version. Its an original from when it first came out, and I wanted
 to test it on my Windows 98 gold system. Found out in the end (with lots of headackes) that
 it would not work unless I had 98SE, which I don't. I thought I could prove them wrong, but
 in the end, I was wrong
 The unit still has that *new* scent. Know what I mean
 -vhelp 4666
	That was what I needed to hear. I should be able to find it now.
 Many Thanks.
 I planning on using it on a non-mce system. It never played nice with MCE 2005. I could record through the Media Center fine and the guide feature worked OK. I just could not get their own PVR S/W to work with it on the MCE system. I wanted more control over the recording process than MCE gave me. OTOH MCE could control my HD DVR for channel changes and such and using the guide I could set up recordings and that worked reliable.
 Having said that I could see where the MCE features would be great for a non tech type.
 Now if I could have just found a player software that was able to be controlled with the MCE remote I'd have been much happier too.
  wintv pvr usb2 in linuxBy diablo in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2011, 09:43
  better unit than my old wintv pvr usb2By diablo in forum Capturing and VCRReplies: 0Last Post: 9th Sep 2011, 10:52
  Hauppauge WinTv USB2 Power supplyBy canadateck in forum Capturing and VCRReplies: 4Last Post: 14th Nov 2008, 14:46
  WinTV-PVR-USB2 Questions/IssuesBy SuPeRFr0sT in forum Capturing and VCRReplies: 4Last Post: 30th Sep 2008, 07:39
  WinTV-PVR-150 MCEBy prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
