I'm a total newbie with MEGUI and X264, but I guess X264 options are not that different from XviD's. Anyway, I'm trying to backup an MPEG2 Source as MP4 using both MEGUI and X264 (the source has some macroblocking, but very hard to see). I'm currently using the following options:
PD-Xbox_HiRes at an average bitrate of 1,300: result = macroblocks on the part of the video shown right here (this is the original source "withouth the macroblocks", only to show where they appear):
If I use zones at a minimum quantizer of 8 for an average quantizer of 26 (same config. options above), I've got that part with no macroblocks at all (same for the final credits), but the overall quality is poor.
Keeping the zones as shown above and config. the quantizers to a min. of 10 and max. of 38, makes the overall quality a lot better, but that part showing the clods/midst will show the macroblocks once again. Besides, the file gets much bigger than that one rendered as XviD (if you want to check out, please download it down there, on my signature: Brazil).
Here are the other settings (avs script):
DGDecode_mpeg2source("C:\brazil_watercolor.d2v",cp u=4,info=3)
ColorMatrix(hints=true)
#deinterlace
#crop
Lanczos4Resize(704,528) # Lanczos4 (Sharp)
Convolution3D("movielq") # Heavy Noise
Questions:
Why can't I achieve the same quality/size as I have done using XviD?
If you've got a better script for AVS, please give me a hint. Help will be greatly appreciated/
Thanks.
Well, I've found a way:
I have used the Profile AE-Maxquality, bitrate at 1,400, inserting 2 zones at Q 8 (for the part shown above and the end credits - effect on the text "brazil"). I'll upload the file later so you can take a look and compare it to the same file rendered as XviD.
Cheers.
Edit: The MP4 file is already here.
x264 Mediainfo to MeGUI x264 Settings
By shagratt71 in forum Video ConversionReplies: 0Last Post: 1st Jan 2012, 04:59 -
Problem with x264.exe (MeGui)
By yomz in forum Video ConversionReplies: 7Last Post: 28th Sep 2011, 21:23 -
MeGUI & x264 settings
By codemaster in forum DVD RippingReplies: 3Last Post: 17th Feb 2011, 13:07 -
MeGUI x264 encoding problem
By follz20 in forum Video ConversionReplies: 0Last Post: 29th Mar 2010, 04:30 -
MEGUI using X264
By Leon8 in forum DVD RippingReplies: 4Last Post: 10th May 2007, 01:34
