Hello Board... I'm trying to find a white paper or some Models and Specs for the Digi Beta Tape.
Does anyone have some resources on this?
Results 1 to 9 of 9
I think you may be referring to ED-Beta, which recorded on metal tape ? If so, I believe there were only a couple models ever made. As to specs, sometimes these units turn up on Ebay, and some specs are linked or included in the listing. If you meant a truly digital tape Beta format, that was probably not a consumer or "Prosumer" model, and would be beyond my familiarity with the subject. (You might try someone here like edDV.)Originally Posted by seb.tatut
There used to be a fairly extensive network of sites on the internet called the "Betamax Webring", but the links I had for it are dead now. So, I'd suggest you start here:
http://www.geocities.com/videoholic2000/index.html
(This is the diminished remnant of a more extensive site, which is no longer up.)
If you are a PAL format user, try
http://www.palsite.com/When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form. -
I assume you are refering to Digital Betacam format.Originally Posted by seb.tatut
What do you want to know about it? The tech? Uses? The types of tape cassettes?
Read this first as an intro then ask more.
http://en.wikipedia.org/wiki/Betacam
You can buy your tapes here
http://www.bhphotovideo.com/c/shop/4135/Broadcast_Tapes_Digital_Betacam.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yes, I'm refering to the Digital Betacam Tape.
I want to know detailed specs. for it... not general ones like found on Wikipedia(http://en.wikipedia.org/wiki/Betacam). I already know that. I need this in order to compile a good reference material for the Telecine department at a FilmLab(they are a little bit confused about tape formats and the sorts).
The more info the better.
Also a good recomandation for a VTR that records on DigiBeta whould be greatly appreciated.
Thank you -
This stuff is so easy to find on Google I suggest you earn your salary or hire a librarian.
http://www.matrixav.com/html/tech_info/dvw/digital_betacam_format.htmRecommends: Kiva.org - Loans that change lives.
Thanks,
I'm actually doing the extra work as a librarian... I should ask an for an extra maybe
Can you tell me the key words you used in the search? -
I used "Digital Betacam" and "SMPTE Digital Betacam" looking for the SMPTE RP.
If you have any application issues not covered in the spec I may have some answers.Recommends: Kiva.org - Loans that change lives.
Back in 1998, I saw ANALOG HD Betacam at the Iowa State Fair and it blows away what we accept for HD today. The display was sponsored by Iowa Public TV and was a previous spec for HD that I think was 1125.
Just saying.... -
That may have been the HiVision system. It was high quality high definition analog component and looked great live but the MUSE digital compressed recorder playback was far inferior to HDCAM.Originally Posted by Scooter_NJRecommends: Kiva.org - Loans that change lives.
Improving Betacam video resolution
By carlmart in forum Video ConversionReplies: 39Last Post: 28th Feb 2011, 13:47 -
Sony DXC-325 and Betacam SP BVV-5 problems
By opl3toshiba in forum Newbie / General discussionsReplies: 0Last Post: 21st Oct 2010, 22:08 -
Capturing Betacam SP video
By jbigfoot in forum Capturing and VCRReplies: 2Last Post: 15th Mar 2010, 18:47 -
What is a Sony BVW-40 Betacam Recorder good for?
By Skubalon in forum Newbie / General discussionsReplies: 7Last Post: 27th Dec 2008, 18:27 -
Betacam SP Sizes
By The Sumerian in forum MediaReplies: 2Last Post: 9th Sep 2007, 14:02
