Hi i'm kinda new to converting and burning movies to dvds, I've a bunch of tv series which are in .rm format and i'd love to burn them onto dvd format so i can watch them on tv.
Just like to know :
1. How do i convert the .rm files to dvd format? Any recommended programs?
2. Is there anyway i can try and compress the files so that i can squeeze more episodes onto one disc? (One .rm file is about 230 mb or so)
2. Subsequently having done so, what's a good DVD authoring tool?
As far as my knowledge goes i do know i have to convert the files into .vob format, and i've tried doing so and burning however when i playback on my DVD player nothing seems to come out.
Hope someone can give me some pointers here, thanks in advance!
1. I would try ConvertXtoDVD.
2. You can squeeze 3-4 hours / dvd with decent quality.
3. ConvertXtodvd will author for you.
If you are looking for free tools it might work with favc together with real alternative. -
Real Media is just awful quality. You can convert them with ConvertXtoDVD, but don't be surprised if the quality is very bad. The more files you to try to fit on a single DVD, the worse the quality will be.
Oh okay, i'm trying out Convertxdvd now, thanks alot for the tip!
**Anyway i have no choice because these shows are usually downloaded in .rm format, presumably because its filesize is small compared to other formats i guess, but i think the quality is still pretty decent .. at least on my screen it is.
*** Update : ConvertxtoDVD worked a treat. Thanks!
What format to use to burn video to DVD to be played in the UK (England)?
By jubbilee in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2011, 02:21 -
Burn from to DVD but what format to play on tv?
By Claxlast in forum Authoring (DVD)Replies: 5Last Post: 18th Mar 2011, 17:57 -
Are the AVCHD and H264 the only HD format to burn the HD DVD?
By coody in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2010, 23:47 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
I've got an animation I did in MPEG format and I want to burn it to a DVD
By el_cid in forum Newbie / General discussionsReplies: 6Last Post: 3rd May 2008, 15:11
