i have an apex 500. not a bad machine-plays vcds but when playing back dvds, there are always subtitles. it must be set to some kind of default but i cant figure out how to turn it off! please help. losing faith in my apex!! :(
I believe that's an Apex bug. If you haven't already...
Try hittng the subtitle button on your remote...if you have one.
Also go into the menu of the DVD and turn of subs. -
i turn it off every time but how do i change the default so when i play the dvd the subs aren't on?
Are you sure it's not the DVD itself? Some of mine always default to subtitles on.
I'm in Australia & have got a Hiteker AD-600A (which is an APEX with a different badge) and had the same problem. I had the Bring it On DVD & couldn't turn the subtitles off at all!!
It was a bug with the firmware of the player itself. I had to upgrade my firmware to get rid of it.
My guess is you've got the same problem and will need to do the same to fix it.
Go here for more info
http://www.dvd-wizards.com/darrenk/ -
my dvd player wont accept the firmware, but thanks anyway. i guess im just stuck having to turn the subs off manually. ahh well. for $180 (cdn) what can you expect. checked at nerdout and no one there had a fix either. :x
Frustration with Toshiba D-VR7 - why?!?!
By ottawadave in forum DVD & Blu-ray RecordersReplies: 7Last Post: 22nd Mar 2012, 01:38 -
My Computer Project = frustration
By jollyjohn in forum ComputerReplies: 36Last Post: 31st Mar 2011, 11:17 -
AC-3 and Wave 5.1 frustration revisited...
By takearushfan in forum AudioReplies: 32Last Post: 19th Aug 2010, 14:54 -
Video Work frustration
By bja5150 in forum Video ConversionReplies: 3Last Post: 18th May 2008, 15:08 -
'jitter' frustration on DVD
By hondo2160 in forum Authoring (DVD)Replies: 3Last Post: 21st Aug 2007, 21:16
