  1. Can you copy/backup a DVD with Imgburn? If so, how do you do it?
    Apr 2004
    Miskatonic U
    If it is unprotected, use the latest version of ImgBurn and select Create Image File from Disc from the new front-end menu. You can then Write Image File to Disc when it is done to complete the copy process.
    If it is a commercial DVD, then the answer is no. You have to rip it first with something like DVDFab HD Decrypter, then either reduce it to fit, then burn, or simply burn, depending on size constraints.
    Read my blog here.
    <----------- Read the guides under "How To". You will find a lot of info there about using ImgBurn. Don't ask to be spoon fed. The info that you want is already there just a couple of clicks away.
    Apr 2004
    Miskatonic U
    I'll just go and put down my spoon . . . . . .
    Read my blog here.
