It used to work perfectly, the awhile ago I was messing around with .mkvs so I installed a few codec packs and what not, after that my Tmpgenc will freeze whenever I load files. I've tried reinstalling it as well as trying different versions and its still freezing, obviously I have uninstalled the codec packs but that didn't help. Ideas ? I've also tried to change the direct show setting in tmpgenc from -1 to 0 to 1...
Edit: An additional note, I have no problem opening the files and watching them.
I would try (re)install haali media splitter and maybe ffdshow.
And I'm moving you to our conversion forum as tmpgenc is a converter. -
Originally Posted by WinSpecToR
Uninstall fddshow completely from your system. -
I have no luck converting MKV to mpg with TMPGenc too.
I followed Baldrick advice, and use one of those all in one tool.
Those toll take more than 10 hours to convert a full length movie MKV to DVD mpeg2. The subtitle in MKV will ended up as embedded text on screen.
MKV is not really a good format to convert from. There are no may player other VLC that can play it
VCR Freezing
By koberulz in forum Capturing and VCRReplies: 9Last Post: 24th Feb 2012, 22:40 -
Picture freezing
By Toes01 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Jan 2012, 14:52 -
Computer Freezing up
By ruknabard in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2007, 17:52 -
Why are my movies freezing?
By bigmatt72401 in forum DVD RippingReplies: 10Last Post: 6th Aug 2007, 05:41 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 11:57
