I'm an amateur videographer. I use a Sony MiniDV cam. I am looking for suggestions/advice as to what program I can use to edit/filter the audio portion of what I film. I am trying to reduce background noise. I don't even know where to start looking for a program to choose from.
Thanks,
Dawson
Try Goldwave too. Load your audio into GW (or one of the apps Soopa mentioned), select a part of the audio with JUST the noise, copy it to the clipboard, then have the prg use that hunka noise on the clipboard to filter out said noise throughout the file.
Stiiv -
http://www.wavosaur.com/tutorials/how-to-remove-noise.php
Try this method! It uses Wavosaur, with the ReaFir plugin from Reaper.
To be honest I haven't tried out Audacity's noise reduction, although I believe it has been enhanced and become more sophisticated?
Adobe Audition's noise reduction is very very good.
OF COURSE IT ALL DEPENDS just exactly WHAT kind of noise...? -
Audacity (newest beta version 1.35) has a pretty good noise reduction "effect" (as filters are called in Audacity).
See http://audacityteam.org/wiki/index.php?title=Noise_Removal -
Try FlexiMusic Audio Editor, i used it remove the noise for my mp3. Been very pleased with it.
IzotopeRXOriginally Posted by dawson54
You select a portion of noise in the recording and the program will train itself to look for that particular noise and get rid of it. It can get rid of hum, background noises, clicks, reduce clipping. etc...
Advice Req: Filtering Audio Files For A Clearer Sound
By Teac23 in forum AudioReplies: 2Last Post: 27th Nov 2008, 09:43 -
Questing about filtering with one of your guides
By Oni87 in forum Newbie / General discussionsReplies: 6Last Post: 21st Oct 2008, 17:26 -
temporal and spatial filtering
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 6th Oct 2007, 10:23 -
filtering scratches/bands
By AlanHK in forum RestorationReplies: 0Last Post: 4th Oct 2007, 06:00 -
Filtering Buzzing Noise from Audio
By Tchail in forum RestorationReplies: 4Last Post: 12th Sep 2007, 23:49
