  1. If i change a .avi into a .mpg and burn with a normal burner, will it work on my dvd?
    Do .mpg really work on dvds?
    Nov 2001
    Canada, Quebec
    I assume that changing is converting so, you can IF you're dvd player reads vcd cause the mpg file will ge an vcd but you CAN'T jsut burn the mpg and then put it in the dvd
