I am currently looking to record matches played on my xbox360 for Gamebattles/MLG. I don't believe I have an open slot for any sort of external capture card so I was looking at something like the Dazzle. My problem however is that I do not play xbox through my TV, I play my xbox on my computer monitor with a VGA hookup and then my computer is connected with DVI. Is there anyway I can capture my games while playing through my computer monitor?
	You would need a VGA to composite box like this.
 http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-composite-vid...uctname-en-asc
 Then you would record the composite video to a VCR or computer capture card.
 Don't expect good quality.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Are there any other ways I could use my monitor with lets say a good Dazzle and get decent quality? Or if i used S-Video rather than the composite video
	The XBox360 doesn't output VGA and composite/s-video at the same time. You would need to run the game to SD composite video (TV set and/or capture card).Originally Posted by kr0n1kRecommends: Kiva.org - Loans that change lives.
	Yes, but would using an s-video cable from the converter output to the Dazzle make the quality of the capture any better than if I used the composite video? Also will using the converter affect the quality of my picture while playing xbox?
	That particular box allows you to run VGA to 1024x768 but will output low quality NTSC composite video.
 How much money do you have to throw at this?Recommends: Kiva.org - Loans that change lives.
	Well I found the Dazzle Platinum for about $50, so in total I'm hoping not to spend any more than $150. I am not looking for anything special but I do want it to look decent with a nice fps. An output like this video would be fine: http://gameroom.gamebattles.com/view/fLwckMbBIcI.html
  Help capturing xbox 360 video when xbox is connected to monitor with vgaBy laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05
  help with capturing video from my xbox360?? read descBy livy111 in forum Capturing and VCRReplies: 0Last Post: 9th Apr 2010, 10:52
  Capturing Xbox 360 using VGABy bigboss50 in forum Capturing and VCRReplies: 14Last Post: 27th Mar 2010, 14:51
  Capturing video from a VGA out into another computerBy jitsuphil in forum Capturing and VCRReplies: 3Last Post: 17th Feb 2009, 11:48
  XBOX360 PS3 - HDMI Full HD CapturingBy TermiATT in forum Capturing and VCRReplies: 6Last Post: 12th Jul 2008, 22:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
