Hello everybody
I have installed a trial version of one program, it uses WordPad as a default text editor.
Then I uninstalled that program and it must have triggered uninstallation of the WordPad, I no longer have it on my computer.
Soon after that NotePad had also disappeared.
Can anybody suggest if there is a way of getting them back without having to reinstall the Windows?
I use a legal WXP Home and, of course, I have a CD
Thx: walter
you can try re-installing. go to control panel/add-remove programs/add-remove windows components. it a tab on the left of the panel. hopefully they are in there...
Thanks Aedipuss, it worked,
I find it weird that a prog, which uses someone else's app, would remove it when uninstalled
walter
Notepad to spellcheck SRTs with underscore facility
By cal_tony in forum SubtitleReplies: 8Last Post: 2nd Nov 2011, 22:43 -
Slipstreaming SP3 on WXP Pro
By jollyjohn in forum ComputerReplies: 3Last Post: 18th Feb 2010, 20:35 -
Task Manager has disappeared
By mysts in forum ComputerReplies: 12Last Post: 6th Apr 2008, 08:51 -
MP4[h264] Chapters with notepad?
By madmillington in forum DVD RippingReplies: 1Last Post: 9th Feb 2008, 23:05 -
WXP copy confirmation reverts to "Yes"
By walter4h in forum ComputerReplies: 0Last Post: 26th Oct 2007, 20:14
