Results 1 to 14 of 14
    Jul 2006
    Hi. I'm trying to convert my avi videos to flv videos. I can convert them successfully from the command. Now, I want to be able to resize my videos to make them smaller. Is there a way to tell ffmpeg to resize my videos so they're no larger than 400 px wide? I couldn't find an option for this. Is there a better tool than ffmpeg that can accomplish this, that is also a command line tool? Thanks!
  2. Member brassplyer's Avatar
    Apr 2008
    Winff is as I understand a gui for ffmpeg that also gives you a command line option. However, I believe the size option command is -s
    Jul 2006
    Thanks for the response. I know the -s will let you set the size; however, I only wanted to set the maximum width. The -s option required ###x###. I only wanted to set a max width.
    Dec 2004
    Triptonia
    no,
    can't do that.
    use mencoder,
    for a ffmpeg gui look to Avanti
    tripp
    Jul 2006
    I don't need a front-end for ffmpeg--I only needed a way to set a max width. We have a process that runs at night that will convert all of our interviews to flash. I looked at mencoder; however, I need something that will run on windows. Thanks!
  6. Banned
    Jun 2007
    UNREACHABLE
    But Mencoder DOES run under Win32.
    Jul 2006
    You're right. When I clicked the mencoder link in the post, it said it was for Linux in the description. So I only assumed.... I'll give this a try. Thanks!
    Sep 2006
    add -s WWWxHHH where WWW is the width, HHH is the hight. If you wanted to make the size 320x200 then do the following
    ffmpeg -Your_first _options -s 320x200 -More_of_your_other_options
    ThymeJ
    Jul 2006
    Do you know of any examples to convert an avi to flv with mencoder? I looked at their site but the options overwhelm me! Thanks!
    Redding, California
    tripp
    Is Avanti still available? Can't seem to find it.
    Dec 2004
    Triptonia
    why don;t you click on it?
    alive and thriving
    Redding, California
    Thanks tripp.... I was clicking on the right side of the page.
  13. Originally Posted by bla4free View Post
    Yes:
    ffmpeg -i input.avi -vf scale="'if(gt(iw,400),400,iw)':-1" output.flv
    (sources: this & this)
    iw = input width
    -1 = whatever height preserves the aspect ratio
