Is there anyway to combine all the movie .vob files to one file without decreasing the quality? Not looking to shrink videos to fit on DVD-5 disks or into menu making, but to just watch them from the HD instead (minus the commercials).
Tried VOB2MPG and it did combine .vob files, but the encoding was of a lossy variety (text had noticeable ghosting).
Anyone with a heads up?
Hi-
If the resulting MPG had ghosting, (probably caused by the choice of deinterlacer), then so did the VOBs. No reencoding is done when converting VOBs to MPGs. VOBs, after all, already contain MPEG-2 video.Tried VOB2MPG and it did combine .vob files, but the encoding was of a lossy variety (text had noticeable ghosting).
You could use DVD Decrypter to decrypt and set the file splitting to none, in order to get one big VOB file. Or you could try VOBMerge. -
Yeah, did a comparision and saw that in screenshots it's lighter than the actual movie itself. This is true in WMP.Originally Posted by manono
I'm using DVDFab 4 Platinum to rip the videos to disk and removing unnecessary .vob files (like those pesky commercials), but it offers no merge tools for easier viewing on the HD. Watching from the HD is soooo much faster especially in seeks, and saves my cheap LiteOn DVD drive from having a meltdown! -
Stop it already. It doesn't recompress. If you did a side-by-side comparison then the first player was using the overlay and the 2nd one wasn't. What happened to your earlier ghosting claim? Did you discover the VOBs also ghosted at playback, if using the same player with the same settings?Yeah, did a comparision and saw that in screenshots it's lighter than the actual movie itself. This is true in WMP.
Why not just play the DVD on the hard drive, rather than the VOBs or MPGs? You won't have to merge anything that way....but it offers no merge tools for easier viewing on the HD.
Converting VOB's to MPEG 2
By HitTheRoad in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 04:46 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Converting .VOB to MPEG-2
By PHNeedsHelp in forum Video ConversionReplies: 2Last Post: 21st Jul 2010, 12:22 -
VOB/Mpeg to AVI??
By Rjupiter in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2008, 08:00 -
vob and mpeg to dvd
By Dekaspace in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2008, 18:36
